Ana içeriğe geç
Disassembling Ericsson CF 388 Phone Casing
Neye ihtiyacın var
  1. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: adım 1, 3 resimden 1. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: adım 1, 3 resimden 2. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: adım 1, 3 resimden 3.
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: adım 2, 3 resimden 1. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: adım 2, 3 resimden 2. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: adım 2, 3 resimden 3.
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Phone Casing: adım 3, 3 resimden 1. Disassembling Ericsson CF 388 Phone Casing: adım 3, 3 resimden 2. Disassembling Ericsson CF 388 Phone Casing: adım 3, 3 resimden 3.
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Phone Casing: adım 4, 2 resimden 1. Disassembling Ericsson CF 388 Phone Casing: adım 4, 2 resimden 2.
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Niccolas Tones
60 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 üyesi
CLEM-BENSON-S12S1G1
3 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 1,145
