Ana içeriğe geç
Disassembling Eureka 1660SP Motor Housing
Neye ihtiyacın var
  1. Disassembling Eureka 1660SP Motor Housing, Motor Housing: adım 1, 2 resimden 1. Disassembling Eureka 1660SP Motor Housing, Motor Housing: adım 1, 2 resimden 2.
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Disassembling Eureka 1660SP Motor Housing: adım 2, 2 resimden 1. Disassembling Eureka 1660SP Motor Housing: adım 2, 2 resimden 2.
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Disassembling Eureka 1660SP Motor Housing: adım 3, 3 resimden 1. Disassembling Eureka 1660SP Motor Housing: adım 3, 3 resimden 2. Disassembling Eureka 1660SP Motor Housing: adım 3, 3 resimden 3.
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jennifer Sheils
4 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S1G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 341
