Ana içeriğe geç
Disassembling Flashlight Light Bulb Components
    1. Disassembling Flashlight Light Bulb Components, Disassembling Flashlight Light Bulb Components: adım 1, 2 resimden 1. Disassembling Flashlight Light Bulb Components, Disassembling Flashlight Light Bulb Components: adım 1, 2 resimden 2.
      • The translucent flashlight before reverse analysis.
      • Twist the light components(red circle) counterclockwise while holding the body of the flashlight (black circle).
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Flashlight Light Bulb Components: adım 2, 3 resimden 1. Disassembling Flashlight Light Bulb Components: adım 2, 3 resimden 2. Disassembling Flashlight Light Bulb Components: adım 2, 3 resimden 3.
      • When removing light component, the black rubber band (red circle) separating body and head falls off. Turn black socket (black circle), which connects bulb to batteries, counterclockwise and disconnect.
      • Bulb (red circle) simply pulled out reflector and lens compartment.
      • The metal connector (red circle) easily slides out open end when twisting off the black socket. This metal piece connects the metal switch supplying power to the bulb.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Flashlight Light Bulb Components: adım 3, 2 resimden 1. Disassembling Flashlight Light Bulb Components: adım 3, 2 resimden 2.
      • The lens connected to the head of the flashlight comes apart using one thumb/finger. Using two other fingers to hold the head's base, the third thumb/finger pushes the lens in the opposite direction with a force >5N.
      • The remaining lens and light reflector component (red circle) of the flashlight pops out of the unit and separates. Simultaneously, the translucent skin (black circle) attached to the head of the flashlight peels off using hands.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling Flashlight Light Bulb Components: adım 4, 1 resimden 1.
      • The complete light bulb component disassembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Phillip Phung
666 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G18
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 145
Her zaman: 6,698
