Ana içeriğe geç
Disassembling Flip Video Circuit Board
Neye ihtiyacın var
  1. Disassembling Flip Video Circuit Board, Outer Shell: adım 1, 2 resimden 1. Disassembling Flip Video Circuit Board, Outer Shell: adım 1, 2 resimden 2.
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Flip Video Circuit Board: adım 2, 1 resimden 1.
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Flip Video Circuit Board: adım 3, 2 resimden 1. Disassembling Flip Video Circuit Board: adım 3, 2 resimden 2.
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Flip Video Circuit Board: adım 4, 1 resimden 1.
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Flip Video Circuit Board: adım 5, 1 resimden 1.
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Flip Video Circuit Board, Circuit Board: adım 6, 1 resimden 1.
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Flip Video Circuit Board: adım 7, 1 resimden 1.
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Flip Video Circuit Board: adım 8, 1 resimden 1.
    • Disconnect the USB port cable from the back side of the circuit board.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Flip Video Circuit Board: adım 9, 1 resimden 1.
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth
100 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G21
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 2,724
