Ana içeriğe geç
Disassembling Flip Video Outer Shell
Neye ihtiyacın var
    1. Disassembling Flip Video Outer Shell, Outer Shell: adım 1, 2 resimden 1. Disassembling Flip Video Outer Shell, Outer Shell: adım 1, 2 resimden 2.
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Flip Video Outer Shell: adım 2, 1 resimden 1.
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Flip Video Outer Shell: adım 3, 2 resimden 1. Disassembling Flip Video Outer Shell: adım 3, 2 resimden 2.
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling Flip Video Outer Shell: adım 4, 1 resimden 1.
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling Flip Video Outer Shell: adım 5, 1 resimden 1.
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth
100 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G21
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 2,506
