Ana içeriğe geç
Disassembling Flip Video USB Port
Neye ihtiyacın var
  1. Disassembling Flip Video USB Port, Outer Shell: adım 1, 2 resimden 1. Disassembling Flip Video USB Port, Outer Shell: adım 1, 2 resimden 2.
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Flip Video USB Port: adım 2, 1 resimden 1.
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Flip Video USB Port: adım 3, 2 resimden 1. Disassembling Flip Video USB Port: adım 3, 2 resimden 2.
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Flip Video USB Port: adım 4, 1 resimden 1.
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Flip Video USB Port: adım 5, 1 resimden 1.
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Flip Video USB Port, Circuit Board: adım 6, 1 resimden 1.
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Flip Video USB Port: adım 7, 1 resimden 1.
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Flip Video USB Port: adım 8, 1 resimden 1.
    • Disconnect the USB port cable from the back side of the circuit board.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Flip Video USB Port: adım 9, 1 resimden 1.
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Flip Video USB Port, USB Port: adım 10, 1 resimden 1.
    • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling Flip Video USB Port: adım 11, 1 resimden 1.
    • Lift wire out of the outer shell slot.
    • The wire mount should stay attached to the wire.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling Flip Video USB Port: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the spring that holds the port door shut.
    • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling Flip Video USB Port: adım 13, 1 resimden 1.
    • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling Flip Video USB Port: adım 14, 1 resimden 1.
    • Remove the USB port cover.
    FixBot'a Sor
    Yorum Ekle
  15. Disassembling Flip Video USB Port: adım 15, 1 resimden 1.
    • Remove the USB slider.
    FixBot'a Sor
    Yorum Ekle
  16. Disassembling Flip Video USB Port: adım 16, 1 resimden 1.
    • Lift out the USB port slowly.
    • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth
100 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G21
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 23
Her zaman: 4,499
