Ana içeriğe geç
FujiFilm FinePix A340 Outer Case Replacement
Neye ihtiyacın var
  1. FujiFilm FinePix A340 Outer Case Replacement, Outer Case: adım 1, 1 resimden 1.
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Outer Case Replacement: adım 2, 3 resimden 1. FujiFilm FinePix A340 Outer Case Replacement: adım 2, 3 resimden 2. FujiFilm FinePix A340 Outer Case Replacement: adım 2, 3 resimden 3.
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Outer Case Replacement: adım 3, 2 resimden 1. FujiFilm FinePix A340 Outer Case Replacement: adım 3, 2 resimden 2.
    • Grab the case with your hands and slowly pull back the outer casing.
Sonuç
Cody
47 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G11
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 3,673
