Ana içeriğe geç
Disassembling Fujifilm Endeavor 100ix Outer Casing
Neye ihtiyacın var
  1. Disassembling Fujifilm Endeavor 100ix Outer Casing, Outer Casing: adım 1, 1 resimden 1.
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 2, 1 resimden 1.
    • Locate the battery door.
  3. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 3, 1 resimden 1.
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 4, 1 resimden 1.
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 5, 1 resimden 1.
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 6, 2 resimden 1. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 6, 2 resimden 2.
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 7, 1 resimden 1.
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 8, 1 resimden 1.
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 9, 1 resimden 1.
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 10, 1 resimden 1.
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 11, 2 resimden 1. Disassembling Fujifilm Endeavor 100ix Outer Casing: adım 11, 2 resimden 2.
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
Sonuç
Eric Nicolai
679 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G5
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 1,340
