Ana içeriğe geç
Disassembling GD Midea FT30-3D Bottom Base
Neye ihtiyacın var
    1. Disassembling GD Midea FT30-3D Bottom Base, Bottom Base: adım 1, 1 resimden 1.
      • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling GD Midea FT30-3D Bottom Base: adım 2, 2 resimden 1. Disassembling GD Midea FT30-3D Bottom Base: adım 2, 2 resimden 2.
      • Locate the gray base support release tabs found on either side pictured in the first image.
      • There are release tabs on each side of the base.
      • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling GD Midea FT30-3D Bottom Base: adım 3, 1 resimden 1.
      • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
      • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling GD Midea FT30-3D Bottom Base: adım 4, 1 resimden 1.
      • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling GD Midea FT30-3D Bottom Base: adım 5, 1 resimden 1.
      • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
      • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
      FixBot'a Sor
      Yorum Ekle
    6. Disassembling GD Midea FT30-3D Bottom Base: adım 6, 1 resimden 1.
      • Once all five screws have been removed the base cover should fall right off with out any effort.
      • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Hartley
450 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G28
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,010
