Ana içeriğe geç
Disassembling Garbage Disposal
    • Operation Test: Run the disposal to check for specific symptoms like unusual sounds or tripping of the overload protector (reset button).
    • Observation: Pay close attention to the type of noise and any response from the overload protector.
    FixBot'a Sor
    Yorum Ekle
    • Installation Check: Confirm that the disposal is properly installed as per the manufacturer's guidelines.
    • Voltage Verification: Check the voltage supply to the disposal using a voltmeter. The standard range should be between 108 and 132 volts.
    FixBot'a Sor
    Yorum Ekle
    • Position a bucket or towels under the disposal to catch any residual water.
    • Disconnecting Lines: Remove the drain line and, if applicable, the dishwasher drain hose.
    • Unlocking Process: Use a service wrench to rotate the mounting flange counterclockwise, carefully supporting the disposal to prevent it from falling.
    FixBot'a Sor
    Yorum Ekle
    • Place the disposal upside down on a sturdy surface.
    • Depending on the model, remove the outer shell and segregate the disposal into its main parts: hopper, drain housing, rotor/shaft assembly, stator, and lower-end bell.
    • Label each wire and part for easy reassembly.
    FixBot'a Sor
    Yorum Ekle
    • Hopper Examination: Look for cracks or corrosion, especially near connections.
    • Gasket Inspection: Check for damage on gaskets and O-rings, replacing them if needed.
    • Switch and Rotor Check: Test the centrifugal switch’s movement and inspect the rotor for wear.
    • Electrical Testing: Use a multimeter to test the capacitor, windings, and switches. For the capacitor, observe the meter as it charges and discharges. Check stator windings for continuity and inspect the start switch for open circuits.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matt Zieminski
49.830 İtibar
28 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.946 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 52
Her zaman: 543
