Ana içeriğe geç
Disassembling Garmin Nuvi 1200 Logic Board
Neye ihtiyacın var
  1. Disassembling Garmin Nuvi 1200 Logic Board, Logic Board: adım 1, 1 resimden 1.
    • Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
    • Once the tool is inserted it can slide around the entire device.
  2. Disassembling Garmin Nuvi 1200 Logic Board: adım 2, 1 resimden 1.
    • Remove four small T5 torx screws.
    • Be gentle, the screws are easily stripped.
  3. Disassembling Garmin Nuvi 1200 Logic Board: adım 3, 2 resimden 1. Disassembling Garmin Nuvi 1200 Logic Board: adım 3, 2 resimden 2.
    • Lift cover off of unit.
    • Be careful not to lose small rubber piece on the bottom right corner.
  4. Disassembling Garmin Nuvi 1200 Logic Board: adım 4, 1 resimden 1.
    • Disconnect ribbon cable from logic board.
  5. Disassembling Garmin Nuvi 1200 Logic Board: adım 5, 1 resimden 1.
    • Remove two T5 torx screws holding down logic board.
    • Disconnect battery.
  6. Disassembling Garmin Nuvi 1200 Logic Board: adım 6, 1 resimden 1.
    • Gently lift the logic board out of the unit
    • Be careful not to damage the battery connector on the top of the unit.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Zachary Landau
206 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 5,257
