Ana içeriğe geç
Disassembling Garmin Nuvi 370 Into Core Components
Neye ihtiyacın var
  1. Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: adım 1, 2 resimden 1. Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: adım 1, 2 resimden 2.
    • Unscrew the two screws on the antenna unit using a torc-head screwdriver.
    • The Torx-Head Screws' size is T-5, which is about 1.5mm.
    • Gently pry open the antenna unit with your fingers.
    • Be careful and try not to damage the small plastic tab.
  2. Disassembling Garmin Nuvi 370 Into Core Components: adım 2, 3 resimden 1. Disassembling Garmin Nuvi 370 Into Core Components: adım 2, 3 resimden 2. Disassembling Garmin Nuvi 370 Into Core Components: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Slide out the inner casing attached to the antenna body.
    • Remove the rotating joint connecting the antenna casing to the main device:
    • Squeeze tweezers into the shown location and compress the spring.
    • Lift out the outer casing while keeping the spring compressed.
    • watch out, as the spring loaded portion may fly out unexpectedly.
  3. Disassembling Garmin Nuvi 370 Into Core Components: adım 3, 1 resimden 1.
    • Using a torx-head screwdriver, unscrew the two revealed screws that connect the front and back of the device.
  4. Disassembling Garmin Nuvi 370 Into Core Components: adım 4, 3 resimden 1. Disassembling Garmin Nuvi 370 Into Core Components: adım 4, 3 resimden 2. Disassembling Garmin Nuvi 370 Into Core Components: adım 4, 3 resimden 3.
    • Insert the plastic opening tool into the center of the edge as shown in first picture.
    • Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture.
  5. Disassembling Garmin Nuvi 370 Into Core Components: adım 5, 3 resimden 1. Disassembling Garmin Nuvi 370 Into Core Components: adım 5, 3 resimden 2. Disassembling Garmin Nuvi 370 Into Core Components: adım 5, 3 resimden 3.
    • Detach the front display from the back panel of the device.
  6. Disassembling Garmin Nuvi 370 Into Core Components: adım 6, 2 resimden 1. Disassembling Garmin Nuvi 370 Into Core Components: adım 6, 2 resimden 2.
    • Using tweezers, gently lift the microphone from its resting position to fully separate the device into two parts.
    • Finally, remove the screw that connects the motherboard to the back casing with a 3mm head driver.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Robert
80 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G65
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 24
Her zaman: 1,412
