Giriş
A step-by-step guide to removing the outer case of the Garmin Nuvi 680.
Neye ihtiyacın var
Flip open the antenna on the back of the device.
Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
This guide works for the Garmin Nuvi 660 and 670 as well.
great instructions thank you! most of it also works for the NUVI 350, this one has an extra screw that holds the circuit board, and the connectors are different. Fixed the on/off button that broke of the soldering tips by re-soldering and adding some support at the back of the switch so this can't happen again.
