Ana içeriğe geç
Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case
Neye ihtiyacın var
  1. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: adım 1, 1 resimden 1.
    • Unplug the toaster from the electrical outlet.
  2. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: adım 2, 2 resimden 1. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: adım 2, 2 resimden 2.
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: adım 3, 1 resimden 1.
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
Sonuç
Ron Gajdos
307 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 üyesi
UMASSD-VIJAYBHASKAR-F13S4G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 1,083
