Ana içeriğe geç
Disassembling General Electric Telephone 2-9710A Handset
Neye ihtiyacın var
  1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: adım 1, 2 resimden 1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: adım 1, 2 resimden 2.
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Handset: adım 2, 3 resimden 1. Disassembling General Electric Telephone 2-9710A Handset: adım 2, 3 resimden 2. Disassembling General Electric Telephone 2-9710A Handset: adım 2, 3 resimden 3.
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: adım 3, 2 resimden 1. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: adım 3, 2 resimden 2.
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Disassembling General Electric Telephone 2-9710A Handset: adım 4, 1 resimden 1.
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Disassembling General Electric Telephone 2-9710A Handset: adım 5, 2 resimden 1. Disassembling General Electric Telephone 2-9710A Handset: adım 5, 2 resimden 2.
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. Disassembling General Electric Telephone 2-9710A Handset: adım 6, 2 resimden 1. Disassembling General Electric Telephone 2-9710A Handset: adım 6, 2 resimden 2.
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. Disassembling General Electric Telephone 2-9710A Handset: adım 7, 1 resimden 1.
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. Disassembling General Electric Telephone 2-9710A Handset: adım 8, 2 resimden 1. Disassembling General Electric Telephone 2-9710A Handset: adım 8, 2 resimden 2.
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. Disassembling General Electric Telephone 2-9710A Handset: adım 9, 2 resimden 1. Disassembling General Electric Telephone 2-9710A Handset: adım 9, 2 resimden 2.
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. Disassembling General Electric Telephone 2-9710A Handset: adım 10, 1 resimden 1.
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
Sonuç
Alles Rebel
72 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G59
4 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 2,902
