Ana içeriğe geç
Disassembling HP Compaq dx2000MT Hard Drive
Neye ihtiyacın var
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: adım 1, 1 resimden 1.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: adım 2, 2 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 2, 2 resimden 2.
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: adım 3, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 3, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive: adım 3, 3 resimden 3.
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: adım 4, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 4, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive: adım 4, 3 resimden 3.
    • Once again, this may take considerable force.
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: adım 5, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: adım 5, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: adım 5, 3 resimden 3.
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: adım 6, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 6, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive: adım 6, 3 resimden 3.
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. Disassembling HP Compaq dx2000MT Hard Drive: adım 7, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 7, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive: adım 7, 3 resimden 3.
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: adım 8, 2 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 8, 2 resimden 2.
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: adım 9, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 9, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive: adım 9, 3 resimden 3.
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: adım 10, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 10, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive: adım 10, 3 resimden 3.
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: adım 11, 3 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 11, 3 resimden 2. Disassembling HP Compaq dx2000MT Hard Drive: adım 11, 3 resimden 3.
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: adım 12, 2 resimden 1. Disassembling HP Compaq dx2000MT Hard Drive: adım 12, 2 resimden 2.
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Eva Pong
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G16
4 Üyeler
17 adet Kılavuz yazıldı
2Kılavuz Yorumları
can i upgrade it to 500gb?
connor gouws - Yanıt
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
ThosD - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 83
Her zaman: 9,578
