Giriş
This guide is a prerequisite for replacing parts such as the battery pack and cooling fan. This part has quite a few screws to remove so just be sure to use your magnetic mat or plastic bag to keep track of them all. The screws are all the same size so the order in which they come out will not matter. Good Luck!
Neye ihtiyacın var
Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
