Parçalar
Hiçbir parça belirtilmedi.
Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
You must remove eleven screws.
Four 9mm screws with the PH0 screwdriver.
Seven 6mm screws with the PH0 screwdriver.
Use the spudger to pry the corners of the laptop near the display hinges.
Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
Use the plastic opening tool to lift the white tab up at the connection.
Pull the cable outwards.
Bir başkası bu kılavuzu tamamladı.
