Giriş
If your back case is scratched or cracked, replacing your back case might be your best option. A new one can be installed using this guide.
Neye ihtiyacın var
Power off your device.
Remove the bottom cover by sliding it off.
Use the plastic opening tool to pry open the rear camera panel.
Remove both screws that are securing the back case.
One 4.0 mm Phillips #0 screw.
One 3.0 mm Phillips #0 screw.
3 farklı kişi bu kılavuzu tamamladı.
