Ana içeriğe geç
Disassembling HTC One V Back Case
Neye ihtiyacın var
  1. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 1. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 2. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: adım 1, 3 resimden 3.
    • Power off your device.
    • Remove the bottom cover by sliding it off.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling HTC One V Back Case: adım 2, 1 resimden 1.
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling HTC One V Back Case: adım 3, 2 resimden 1. Disassembling HTC One V Back Case: adım 3, 2 resimden 2.
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling HTC One V Back Case: adım 4, 3 resimden 1. Disassembling HTC One V Back Case: adım 4, 3 resimden 2. Disassembling HTC One V Back Case: adım 4, 3 resimden 3.
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: adım 5, 3 resimden 1. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: adım 5, 3 resimden 2. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: adım 5, 3 resimden 3.
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling HTC One V Back Case: adım 6, 3 resimden 1. Disassembling HTC One V Back Case: adım 6, 3 resimden 2. Disassembling HTC One V Back Case: adım 6, 3 resimden 3.
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling HTC One V Back Case: adım 7, 3 resimden 1. Disassembling HTC One V Back Case: adım 7, 3 resimden 2. Disassembling HTC One V Back Case: adım 7, 3 resimden 3.
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Lucido
852 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Blackwell Winter 2015 USF Tampa, Team 1-3, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S1G3
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 3,543
