Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Power off your device.
Remove the bottom cover by sliding it off.
Remove the SIM card.
Remove the four screws securing the bottom casing.
Two 3.0 mm Phillips #0 screws in the top left and right corners.
Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
Remove the 2.0 mm Phillips #0 screws on either side of the phone.
Use a plastic opening tool to pry open the bottom casing.
Remove the bottom casing by pulling it towards you.
Use the plastic opening tool to pry open the rear camera panel.
Remove both screws that are securing the back case.
One 4.0 mm Phillips #0 screw.
One 3.0 mm Phillips #0 screw.
Use a Jimmy to pry up the OEM SIM and SD card reader contact.
Using both thumbs, gently push on the two bottom rear corners of the motherboard.
Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
3 farklı kişi bu kılavuzu tamamladı.
