Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
  1. Power off your device. Remove the bottom cover by sliding it off. Remove the bottom cover by sliding it off.
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. Remove the SIM card.
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. Remove the 2.0 mm Phillips #0 screws on either side of the phone. Remove the 2.0 mm Phillips #0 screws on either side of the phone.
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. Use a plastic opening tool to pry open the bottom casing. Remove the bottom casing by pulling it towards you. Remove the bottom casing by pulling it towards you.
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. Use the plastic opening tool to pry open the rear camera panel. Remove both screws that are securing the back case. One 4.0 mm Phillips #0 screw.
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
  6. Use a Jimmy to pry up the OEM SIM and SD card reader contact. Pry from right to left to avoid potential damages to the ribbon. Pry from right to left to avoid potential damages to the ribbon.
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
  7. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Using both thumbs, gently push on the two bottom rear corners of the motherboard. Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening. Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
  9. Pry up the battery with the flat end of the spudger.
    • Pry up the battery with the flat end of the spudger.
  10. Gently lift up the battery away from the edge of its housing. Use the point end of the spudger to push the connection out of its housing. Use the point end of the spudger to push the connection out of its housing.
    • Gently lift up the battery away from the edge of its housing.
    • Use the point end of the spudger to push the connection out of its housing.
  11. Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens. Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens. Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
    • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
  12. Pry off the camera lens using a plastic opening tool.
    • Pry off the camera lens using a plastic opening tool.
  13. Pry the vibrator out of the housing with a spudger. Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
    • Pry the vibrator out of the housing with a spudger.
    • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
  14. Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors. Remove the 3.0 mm Phillips #0 screw. Remove the 3.0 mm Phillips #0 screw.
    • Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors.
    • Remove the 3.0 mm Phillips #0 screw.
  15. Using tweezers, pull back on the tape located on the bottom corners of the motherboard. Using tweezers, pull back on the tape located on the bottom corners of the motherboard. Using tweezers, pull back on the tape located on the bottom corners of the motherboard.
    • Using tweezers, pull back on the tape located on the bottom corners of the motherboard.
  16. Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard. Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard.
    • Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard.
  17. Place your phone on its side so that you can gently pull up on the motherboard to expose its last connector.
    • Place your phone on its side so that you can gently pull up on the motherboard to expose its last connector.
    • Using the flat end of the spudger, pop of the connector.
Sonuç
Joshua Rhoden
232 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team 1-3, Blackwell Winter 2015 USF Tampa, Team 1-3, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S1G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 46
