Ana içeriğe geç
Disassembling HTC Touch Pro CDMA Verizon Basic Parts
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
    1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts, Battery: adım 1, 1 resimden 1.
      • Remove the back cover (not pictured) to your phone.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 2, 2 resimden 1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 2, 2 resimden 2.
      • To remove the battery, place your thumb beneath the tab and begin to lift.
      • Pinching the battery, lift up at an angle from the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts, Basic Parts: adım 3, 1 resimden 1.
      • Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
      • It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 4, 3 resimden 1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 4, 3 resimden 2. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 4, 3 resimden 3.
      • Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
      • Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 5, 3 resimden 1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 5, 3 resimden 2. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 5, 3 resimden 3.
      • Next, remove the casing that covers the camera and motherboard.
      • To do this, place your thumbnail in any of the grooves along either side and pry it open.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 6, 2 resimden 1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 6, 2 resimden 2.
      • Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
      • Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 7, 3 resimden 1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 7, 3 resimden 2. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 7, 3 resimden 3.
      • Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 8, 3 resimden 1. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 8, 3 resimden 2. Disassembling HTC Touch Pro CDMA Verizon Basic Parts: adım 8, 3 resimden 3.
      • Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
      • Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jack Bowen
79 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-67, Walters Spring 2011 Cal Poly, Team 20-67, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G67
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 1,850
