Ana içeriğe geç
Disassembling Home Stereo and Theater Philips MCD288
Neye ihtiyacın var
  1. Disassembling Home Stereo and Theater Philips MCD288, Undo screws: adım 1, 1 resimden 1.
    • remove the 4 screws on the bottem of the main set
  2. Disassembling Home Stereo and Theater Philips MCD288, Expose main latches: adım 2, 1 resimden 1.
    • Lift the aluminium pane at both sides with a spudger.
  3. Disassembling Home Stereo and Theater Philips MCD288, Start with the bottom edges: adım 3, 1 resimden 1.
    • To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
    • hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
  4. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: adım 4, 2 resimden 1. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: adım 4, 2 resimden 2.
    • To detach the sides, pull a main latch towards you and keep on lifting the top part further.
    • repeat for three latches on each side.
  5. Disassembling Home Stereo and Theater Philips MCD288, The inside: adım 5, 2 resimden 1. Disassembling Home Stereo and Theater Philips MCD288, The inside: adım 5, 2 resimden 2.
    • These pictures show the latches on each edge and on the top of the set.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Philipp
71 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 99
Her zaman: 8,124
