Ana içeriğe geç
Disassembling IBM ThinkPad A30 CD Drive
  1. Disassembling IBM ThinkPad A30 CD Drive, Battery: adım 1, 2 resimden 1. Disassembling IBM ThinkPad A30 CD Drive, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling IBM ThinkPad A30 CD Drive, CD Drive: adım 2, 3 resimden 1. Disassembling IBM ThinkPad A30 CD Drive, CD Drive: adım 2, 3 resimden 2. Disassembling IBM ThinkPad A30 CD Drive, CD Drive: adım 2, 3 resimden 3.
    • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
    • Slide the switch to the right. A black plastic tab will pop out.
    • Pull the plastic tab to expose the CD drive.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling IBM ThinkPad A30 CD Drive: adım 3, 1 resimden 1.
    • Carefully pull the CD drive out from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jessica
162 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G44
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 2,828
