Ana içeriğe geç
Disassembling IBM ThinkPad A30 CPU
Neye ihtiyacın var
  1. Disassembling IBM ThinkPad A30 CPU, Battery: adım 1, 2 resimden 1. Disassembling IBM ThinkPad A30 CPU, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling IBM ThinkPad A30 CPU, Hard Drive: adım 2, 3 resimden 1. Disassembling IBM ThinkPad A30 CPU, Hard Drive: adım 2, 3 resimden 2. Disassembling IBM ThinkPad A30 CPU, Hard Drive: adım 2, 3 resimden 3.
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling IBM ThinkPad A30 CPU, Upper Case: adım 3, 1 resimden 1.
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling IBM ThinkPad A30 CPU: adım 4, 1 resimden 1.
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling IBM ThinkPad A30 CPU: adım 5, 2 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 5, 2 resimden 2.
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling IBM ThinkPad A30 CPU: adım 6, 3 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 6, 3 resimden 2. Disassembling IBM ThinkPad A30 CPU: adım 6, 3 resimden 3.
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling IBM ThinkPad A30 CPU: adım 7, 3 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 7, 3 resimden 2. Disassembling IBM ThinkPad A30 CPU: adım 7, 3 resimden 3.
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling IBM ThinkPad A30 CPU: adım 8, 2 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 8, 2 resimden 2.
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling IBM ThinkPad A30 CPU: adım 9, 3 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 9, 3 resimden 2. Disassembling IBM ThinkPad A30 CPU: adım 9, 3 resimden 3.
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling IBM ThinkPad A30 CPU, Display Assembly: adım 10, 1 resimden 1.
    • Remove the 5.6mm screw that holds the LCD to the upper case.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling IBM ThinkPad A30 CPU: adım 11, 3 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 11, 3 resimden 2. Disassembling IBM ThinkPad A30 CPU: adım 11, 3 resimden 3.
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling IBM ThinkPad A30 CPU: adım 12, 2 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 12, 2 resimden 2.
    • Pull out the white tab connecting the LCD to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling IBM ThinkPad A30 CPU: adım 13, 2 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 13, 2 resimden 2.
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling IBM ThinkPad A30 CPU: adım 14, 3 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 14, 3 resimden 2. Disassembling IBM ThinkPad A30 CPU: adım 14, 3 resimden 3.
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
    FixBot'a Sor
    Yorum Ekle
  15. Disassembling IBM ThinkPad A30 CPU, Fan: adım 15, 1 resimden 1.
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
    FixBot'a Sor
    Yorum Ekle
  16. Disassembling IBM ThinkPad A30 CPU: adım 16, 1 resimden 1.
    • Lift the heatsink bracket up.
    FixBot'a Sor
    Yorum Ekle
  17. Disassembling IBM ThinkPad A30 CPU: adım 17, 3 resimden 1. Disassembling IBM ThinkPad A30 CPU: adım 17, 3 resimden 2. Disassembling IBM ThinkPad A30 CPU: adım 17, 3 resimden 3.
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
    FixBot'a Sor
    Yorum Ekle
  18. Disassembling IBM ThinkPad A30 CPU, CPU: adım 18, 2 resimden 1. Disassembling IBM ThinkPad A30 CPU, CPU: adım 18, 2 resimden 2.
    • Use a flathead to turn the screw 180 degrees.
    • Remove the CPU by lifting it upwards.
    • If the CPU is reusable, place it in an antistatic bag and away from moisture.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jessica
162 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G44
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 42
Her zaman: 3,335
