Ana içeriğe geç
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: adım 1, 2 resimden 1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: adım 2, 2 resimden 1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: adım 2, 2 resimden 2.
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: adım 3, 2 resimden 1. Disassembling IBM ThinkPad A30 Floppy Disk Drive: adım 3, 2 resimden 2.
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
162 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G44
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 3,228
