Ana içeriğe geç
Disassembling IBM ThinkPad A30 Motherboard
Neye ihtiyacın var
  1. Disassembling IBM ThinkPad A30 Motherboard, Battery: adım 1, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: adım 2, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: adım 2, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: adım 2, 3 resimden 3.
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling IBM ThinkPad A30 Motherboard, CD Drive: adım 3, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard, CD Drive: adım 3, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard, CD Drive: adım 3, 3 resimden 3.
    • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
    • Slide the switch to the right. A black plastic tab will pop out.
    • Pull the plastic tab to expose the CD drive.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling IBM ThinkPad A30 Motherboard: adım 4, 1 resimden 1.
    • Carefully pull the CD drive out from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: adım 5, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: adım 5, 2 resimden 2.
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling IBM ThinkPad A30 Motherboard: adım 6, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 6, 2 resimden 2.
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling IBM ThinkPad A30 Motherboard, Upper Case: adım 7, 1 resimden 1.
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling IBM ThinkPad A30 Motherboard: adım 8, 1 resimden 1.
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling IBM ThinkPad A30 Motherboard: adım 9, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 9, 2 resimden 2.
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling IBM ThinkPad A30 Motherboard: adım 10, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 10, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard: adım 10, 3 resimden 3.
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling IBM ThinkPad A30 Motherboard: adım 11, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 11, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard: adım 11, 3 resimden 3.
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling IBM ThinkPad A30 Motherboard: adım 12, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 12, 2 resimden 2.
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling IBM ThinkPad A30 Motherboard: adım 13, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 13, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard: adım 13, 3 resimden 3.
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling IBM ThinkPad A30 Motherboard, Display Assembly: adım 14, 1 resimden 1.
    • Remove the 5.6mm screw that holds the LCD to the upper case.
    FixBot'a Sor
    Yorum Ekle
  15. Disassembling IBM ThinkPad A30 Motherboard: adım 15, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 15, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard: adım 15, 3 resimden 3.
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
    FixBot'a Sor
    Yorum Ekle
  16. Disassembling IBM ThinkPad A30 Motherboard: adım 16, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 16, 2 resimden 2.
    • Pull out the white tab connecting the LCD to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  17. Disassembling IBM ThinkPad A30 Motherboard: adım 17, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 17, 2 resimden 2.
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
    FixBot'a Sor
    Yorum Ekle
  18. Disassembling IBM ThinkPad A30 Motherboard: adım 18, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 18, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard: adım 18, 3 resimden 3.
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
    FixBot'a Sor
    Yorum Ekle
  19. Disassembling IBM ThinkPad A30 Motherboard, Fan: adım 19, 1 resimden 1.
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
    FixBot'a Sor
    Yorum Ekle
  20. Disassembling IBM ThinkPad A30 Motherboard: adım 20, 1 resimden 1.
    • Lift the heatsink bracket up.
    FixBot'a Sor
    Yorum Ekle
  21. Disassembling IBM ThinkPad A30 Motherboard: adım 21, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 21, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard: adım 21, 3 resimden 3.
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
    FixBot'a Sor
    Yorum Ekle
  22. Disassembling IBM ThinkPad A30 Motherboard, CPU: adım 22, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard, CPU: adım 22, 2 resimden 2.
    • Use a flathead to turn the screw 180 degrees.
    • Remove the CPU by lifting it upwards.
    • If the CPU is reusable, place it in an antistatic bag and away from moisture.
    FixBot'a Sor
    Yorum Ekle
  23. Disassembling IBM ThinkPad A30 Motherboard, Motherboard: adım 23, 1 resimden 1.
    • Locate the floppy drive bay.
    • Remove the four 5.6mm screws.
    • Remove the 16mm screw.
    FixBot'a Sor
    Yorum Ekle
  24. Disassembling IBM ThinkPad A30 Motherboard: adım 24, 3 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 24, 3 resimden 2. Disassembling IBM ThinkPad A30 Motherboard: adım 24, 3 resimden 3.
    • Turn the laptop over so that the battery is towards you.
    • Locate the modem and ethernet card bay.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
    FixBot'a Sor
    Yorum Ekle
  25. Disassembling IBM ThinkPad A30 Motherboard: adım 25, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 25, 2 resimden 2.
    • Remove the four 9.1mm screws attached to the modem and ethernet cards.
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    FixBot'a Sor
    Yorum Ekle
  26. Disassembling IBM ThinkPad A30 Motherboard: adım 26, 1 resimden 1.
    • Locate the hard drive slot.
    • Remove the 8.8mm screw with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  27. Disassembling IBM ThinkPad A30 Motherboard: adım 27, 1 resimden 1.
    • Turn the laptop over again and orient it as shown.
    • Lift the left side of the floppy disk bay and and pull it out.
    • The black lever will pop out.
    FixBot'a Sor
    Yorum Ekle
  28. Disassembling IBM ThinkPad A30 Motherboard: adım 28, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 28, 2 resimden 2.
    • Locate the CD Drive Bay
    • Remove the three 5.6mm screws.
    • Lift the right side and pull the CD drive bay out.
    FixBot'a Sor
    Yorum Ekle
  29. Disassembling IBM ThinkPad A30 Motherboard: adım 29, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 29, 2 resimden 2.
    • Once the CD drive bay is removed, locate the speaker data and power cables.
    • Remove the cables from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  30. Disassembling IBM ThinkPad A30 Motherboard: adım 30, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 30, 2 resimden 2.
    • Locate the expansion bay.
    • Lift and remove the expansion bay.
    FixBot'a Sor
    Yorum Ekle
  31. Disassembling IBM ThinkPad A30 Motherboard: adım 31, 1 resimden 1.
    • Rotate the laptop so that the back ports are facing you.
    FixBot'a Sor
    Yorum Ekle
  32. Disassembling IBM ThinkPad A30 Motherboard: adım 32, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 32, 2 resimden 2.
    • Remove the three 5.8mm screws with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  33. Disassembling IBM ThinkPad A30 Motherboard: adım 33, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 33, 2 resimden 2.
    • Remove the six 11mm nuts with a wrench.
    • Pliers can be used, but are not recommended.
    FixBot'a Sor
    Yorum Ekle
  34. Disassembling IBM ThinkPad A30 Motherboard: adım 34, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 34, 2 resimden 2.
    • Rotate the laptop to its original position.
    • Remove the 5.6mm screw located on the upper right corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  35. Disassembling IBM ThinkPad A30 Motherboard: adım 35, 2 resimden 1. Disassembling IBM ThinkPad A30 Motherboard: adım 35, 2 resimden 2.
    • The wireless and bluetooth cards are connected to the motherboard!
    • Pull out the motherboard towards you carefully.
    • Place the motherboard somewhere dry and clean.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alan
380 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G44
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 9,091
