Ana içeriğe geç
Disassembling IBM ThinkPad A30 Speakers
Neye ihtiyacın var
  1. Disassembling IBM ThinkPad A30 Speakers, Battery: adım 1, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling IBM ThinkPad A30 Speakers, Upper Case: adım 2, 1 resimden 1.
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling IBM ThinkPad A30 Speakers: adım 3, 1 resimden 1.
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling IBM ThinkPad A30 Speakers: adım 4, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 4, 2 resimden 2.
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling IBM ThinkPad A30 Speakers: adım 5, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 5, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 5, 3 resimden 3.
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling IBM ThinkPad A30 Speakers: adım 6, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 6, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 6, 3 resimden 3.
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling IBM ThinkPad A30 Speakers: adım 7, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 7, 2 resimden 2.
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling IBM ThinkPad A30 Speakers: adım 8, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 8, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 8, 3 resimden 3.
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling IBM ThinkPad A30 Speakers, Display Assembly: adım 9, 1 resimden 1.
    • Remove the 5.6mm screw that holds the LCD to the upper case.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling IBM ThinkPad A30 Speakers: adım 10, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 10, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 10, 3 resimden 3.
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling IBM ThinkPad A30 Speakers: adım 11, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 11, 2 resimden 2.
    • Pull out the white tab connecting the LCD to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling IBM ThinkPad A30 Speakers: adım 12, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 12, 2 resimden 2.
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling IBM ThinkPad A30 Speakers: adım 13, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 13, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 13, 3 resimden 3.
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling IBM ThinkPad A30 Speakers, Fan: adım 14, 1 resimden 1.
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
    FixBot'a Sor
    Yorum Ekle
  15. Disassembling IBM ThinkPad A30 Speakers: adım 15, 1 resimden 1.
    • Lift the heatsink bracket up.
    FixBot'a Sor
    Yorum Ekle
  16. Disassembling IBM ThinkPad A30 Speakers: adım 16, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 16, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 16, 3 resimden 3.
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
    FixBot'a Sor
    Yorum Ekle
  17. Disassembling IBM ThinkPad A30 Speakers, Speakers: adım 17, 1 resimden 1.
    • Locate the floppy drive bay.
    • Remove the four 5.6mm screws.
    • Remove the 16mm screw.
    FixBot'a Sor
    Yorum Ekle
  18. Disassembling IBM ThinkPad A30 Speakers: adım 18, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 18, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 18, 3 resimden 3.
    • Turn the laptop over so the battery is facing you.
    • Locate the modem and ethernet card bay.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
    FixBot'a Sor
    Yorum Ekle
  19. Disassembling IBM ThinkPad A30 Speakers: adım 19, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 19, 2 resimden 2.
    • Remove the four 9.1mm screws attached to the modem and ethernet cards.
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    FixBot'a Sor
    Yorum Ekle
  20. Disassembling IBM ThinkPad A30 Speakers: adım 20, 1 resimden 1.
    • Locate the hard drive slot.
    • Remove the 8.8mm screw with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  21. Disassembling IBM ThinkPad A30 Speakers: adım 21, 1 resimden 1.
    • Turn the laptop over again and orient it as shown.
    • Lift the left side of the floppy disk bay and and pull it out.
    • The black lever will pop out.
    FixBot'a Sor
    Yorum Ekle
  22. Disassembling IBM ThinkPad A30 Speakers: adım 22, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 22, 2 resimden 2.
    • Locate the CD Drive Bay
    • Remove the three 5.6mm screws.
    • Lift the right side and pull the CD drive bay out.
    FixBot'a Sor
    Yorum Ekle
  23. Disassembling IBM ThinkPad A30 Speakers: adım 23, 1 resimden 1.
    • Locate the speakers on the bottom left and right of the ThinkPad A30.
    FixBot'a Sor
    Yorum Ekle
  24. Disassembling IBM ThinkPad A30 Speakers: adım 24, 3 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 24, 3 resimden 2. Disassembling IBM ThinkPad A30 Speakers: adım 24, 3 resimden 3.
    • Remove the 5.6mm screws on each speaker.
    • Pull the right speaker out, making sure there is still slack in the wire.
    FixBot'a Sor
    Yorum Ekle
  25. Disassembling IBM ThinkPad A30 Speakers: adım 25, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 25, 2 resimden 2.
    • Pull the blue tab that holds the speaker chip and pull the chip out.
    FixBot'a Sor
    Yorum Ekle
  26. Disassembling IBM ThinkPad A30 Speakers: adım 26, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 26, 2 resimden 2.
    • Remove the wires from the white tabs by lifting the black wire casing.
    FixBot'a Sor
    Yorum Ekle
  27. Disassembling IBM ThinkPad A30 Speakers: adım 27, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 27, 2 resimden 2.
    • Lift the left speaker out.
    FixBot'a Sor
    Yorum Ekle
  28. Disassembling IBM ThinkPad A30 Speakers: adım 28, 2 resimden 1. Disassembling IBM ThinkPad A30 Speakers: adım 28, 2 resimden 2.
    • Remove the speaker data and power cables by pulling them from the motherboard.
    • You have successfully removed the ThinkPad A30 speakers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alan
380 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G44
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 2,677
