Giriş
In this step-by-step guide, you will be removing the speakers from the Thinkpad A30 for replacement.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Locate the 4 screws that will need to be removed.
Remove the 5.6mm (yellow) and three 16.1mm (red) screws.
Locate the floppy drive bay.
Remove the four 5.6mm screws.
Remove the 16mm screw.
Bir başkası bu kılavuzu tamamladı.
