Ana içeriğe geç
Disassembling IBM ThinkPad A30 Upper Case
Neye ihtiyacın var
  1. Disassembling IBM ThinkPad A30 Upper Case, Battery: adım 1, 2 resimden 1. Disassembling IBM ThinkPad A30 Upper Case, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: adım 2, 3 resimden 1. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: adım 2, 3 resimden 2. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: adım 2, 3 resimden 3.
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: adım 3, 1 resimden 1.
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling IBM ThinkPad A30 Upper Case: adım 4, 1 resimden 1.
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling IBM ThinkPad A30 Upper Case: adım 5, 2 resimden 1. Disassembling IBM ThinkPad A30 Upper Case: adım 5, 2 resimden 2.
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling IBM ThinkPad A30 Upper Case: adım 6, 3 resimden 1. Disassembling IBM ThinkPad A30 Upper Case: adım 6, 3 resimden 2. Disassembling IBM ThinkPad A30 Upper Case: adım 6, 3 resimden 3.
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling IBM ThinkPad A30 Upper Case: adım 7, 3 resimden 1. Disassembling IBM ThinkPad A30 Upper Case: adım 7, 3 resimden 2. Disassembling IBM ThinkPad A30 Upper Case: adım 7, 3 resimden 3.
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling IBM ThinkPad A30 Upper Case: adım 8, 2 resimden 1. Disassembling IBM ThinkPad A30 Upper Case: adım 8, 2 resimden 2.
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling IBM ThinkPad A30 Upper Case: adım 9, 3 resimden 1. Disassembling IBM ThinkPad A30 Upper Case: adım 9, 3 resimden 2. Disassembling IBM ThinkPad A30 Upper Case: adım 9, 3 resimden 3.
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alan
380 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G44
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 37
Her zaman: 2,633
