Giriş
The lower bracket needs to be removed to get to some components of the laptop.
Parçalar
Hiçbir parçaya gerek yok.
  1. Unscrew the 20 Phillips screws on the underside of the T42.
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. Unscrew the 2 Phillips screws on both sides of the T42's rear.
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  5. Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  6. The metal bracket will now be free to move, grasp it and remove it from the device. The metal bracket will now be free to move, grasp it and remove it from the device.
    • The metal bracket will now be free to move, grasp it and remove it from the device.
  7. Remove the small rubber piece that is covering the T42's microphone,
    • Remove the small rubber piece that is covering the T42's microphone,
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gerald Watanabe
198 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
30 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 4
Her zaman: 3,157
