Ana içeriğe geç
Disassembling IBM ThinkPad T42 Lower Bracket
Neye ihtiyacın var
  1. Disassembling IBM ThinkPad T42 Lower Bracket, Bottom cover: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. Disassembling IBM ThinkPad T42 Lower Bracket, Rear screws: adım 2, 1 resimden 1.
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. Disassembling IBM ThinkPad T42 Lower Bracket, Keyboard and Trackpad: adım 3, 1 resimden 1.
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. Disassembling IBM ThinkPad T42 Lower Bracket: adım 4, 2 resimden 1. Disassembling IBM ThinkPad T42 Lower Bracket: adım 4, 2 resimden 2.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. Disassembling IBM ThinkPad T42 Lower Bracket, Lower Bracket: adım 5, 2 resimden 1. Disassembling IBM ThinkPad T42 Lower Bracket, Lower Bracket: adım 5, 2 resimden 2.
    • Grasp the metal bracket to remove it from the device.
  6. Disassembling IBM ThinkPad T42 Lower Bracket, Microphone cover: adım 6, 1 resimden 1.
    • Remove the rubber cover from the microphone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gerald Watanabe
288 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 70
Her zaman: 3,839
