Ana içeriğe geç
Disassembling IBM ThinkPad T42 Plastic Edge Cover
Neye ihtiyacın var
  1. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Bottom cover: adım 1, 1 resimden 1.
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Rear screws: adım 2, 1 resimden 1.
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Keyboard and Trackpad: adım 3, 1 resimden 1.
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. Disassembling IBM ThinkPad T42 Plastic Edge Cover: adım 4, 2 resimden 1. Disassembling IBM ThinkPad T42 Plastic Edge Cover: adım 4, 2 resimden 2.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Plastic Edge Cover: adım 5, 2 resimden 1. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Plastic Edge Cover: adım 5, 2 resimden 2.
    • Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
Sonuç
Gerald Watanabe
279 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
35 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 6,869
