Ana içeriğe geç
Disassembling Insignia NS-B2110 Bottom Panel
Neye ihtiyacın var
  1. Disassembling Insignia NS-B2110 Bottom Panel, Battery: adım 1, 2 resimden 1. Disassembling Insignia NS-B2110 Bottom Panel, Battery: adım 1, 2 resimden 2.
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Disassembling Insignia NS-B2110 Bottom Panel: adım 2, 2 resimden 1. Disassembling Insignia NS-B2110 Bottom Panel: adım 2, 2 resimden 2.
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Disassembling Insignia NS-B2110 Bottom Panel, Bottom Panel: adım 3, 1 resimden 1.
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Disassembling Insignia NS-B2110 Bottom Panel: adım 4, 2 resimden 1. Disassembling Insignia NS-B2110 Bottom Panel: adım 4, 2 resimden 2.
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Disassembling Insignia NS-B2110 Bottom Panel: adım 5, 3 resimden 1. Disassembling Insignia NS-B2110 Bottom Panel: adım 5, 3 resimden 2. Disassembling Insignia NS-B2110 Bottom Panel: adım 5, 3 resimden 3.
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
Sonuç
Nikki
104 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G31
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 240
