Ana içeriğe geç
Disassembling JBL Tour Pro 3 case
Neye ihtiyacın var
  1. Disassembling JBL Tour Pro 3 case, Top ring: adım 1, 3 resimden 1. Disassembling JBL Tour Pro 3 case, Top ring: adım 1, 3 resimden 2. Disassembling JBL Tour Pro 3 case, Top ring: adım 1, 3 resimden 3.
    • Start by opening the case and removing the ring at the top by prying it off of the case
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling JBL Tour Pro 3 case, Touchscreen: adım 2, 1 resimden 1.
    • Now that the ring is off, heat up the touchscreen to loosen the adhesive behind it
    • Remove the touchscreen by using a prying pick to get in between the buds crevices and the touchscreen and pry it open just enough to press another pick in between the touchscreen and the case .
    • Use some isopropal alcohol to desolve the adhesive
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling JBL Tour Pro 3 case, insides: adım 3, 1 resimden 1.
    • Pry out the insides by using the prying picks in between the sides
    • Be careful for there is a cable attached to a daughter board which is screwed down at the bottom of the case.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling JBL Tour Pro 3 case, Daughter board: adım 4, 2 resimden 1. Disassembling JBL Tour Pro 3 case, Daughter board: adım 4, 2 resimden 2.
    • Remove the 2 +0 size screws and pull out the daughter board
    FixBot'a Sor
    Yorum Ekle
Sonuç
Smokey
109 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 62
Her zaman: 308
