Ana içeriğe geç
Disassembling JVC GR-D290U
Neye ihtiyacın var
  1. Disassembling JVC GR-D290U, JVC GR-D290U: adım 1, 2 resimden 1. Disassembling JVC GR-D290U, JVC GR-D290U: adım 1, 2 resimden 2.
    • Open the liquid-crystal display (LCD) screen.
    • Using a Phillips #1 screwdriver, remove the two hinge screws.
    • Remove the hinge cover. Shut the screen after the cover is removed.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling JVC GR-D290U: adım 2, 3 resimden 1. Disassembling JVC GR-D290U: adım 2, 3 resimden 2. Disassembling JVC GR-D290U: adım 2, 3 resimden 3.
    • Flip the camera over to look at the bottom panel.
    • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
    • Push the eject button beneath the bottom panel to open the cassette cover.
    • Shut the cassette cover.
    • Place the camera upright.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling JVC GR-D290U: adım 3, 1 resimden 1.
    • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
    • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
    • Replace the dark gray tab and close the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling JVC GR-D290U: adım 4, 1 resimden 1.
    • Go to the side of the camera that is opposite the LCD screen.
    • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling JVC GR-D290U: adım 5, 2 resimden 1. Disassembling JVC GR-D290U: adım 5, 2 resimden 2.
    • Go to the side of the camera that has the LCD screen.
    • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
    • Pry the top cover from the bottom cover until you hear a snapping sound.
    • Gently remove the top cover from the camera base.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
justin chen
47 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-69, Johann Spring 2010 Cal Poly, Team 18-69, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G69
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 51
Her zaman: 4,652
