Ana içeriğe geç
Disassembling KDDI Kyocera A5521K Faceplate
  1. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: adım 1, 3 resimden 1. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: adım 1, 3 resimden 2. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: adım 1, 3 resimden 3.
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Faceplate: adım 2, 3 resimden 1. Disassembling KDDI Kyocera A5521K Faceplate: adım 2, 3 resimden 2. Disassembling KDDI Kyocera A5521K Faceplate: adım 2, 3 resimden 3.
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Faceplate, Faceplate: adım 3, 3 resimden 1. Disassembling KDDI Kyocera A5521K Faceplate, Faceplate: adım 3, 3 resimden 2. Disassembling KDDI Kyocera A5521K Faceplate, Faceplate: adım 3, 3 resimden 3.
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. Disassembling KDDI Kyocera A5521K Faceplate: adım 4, 1 resimden 1.
    • Remove the screws using a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Faceplate: adım 5, 3 resimden 1. Disassembling KDDI Kyocera A5521K Faceplate: adım 5, 3 resimden 2. Disassembling KDDI Kyocera A5521K Faceplate: adım 5, 3 resimden 3.
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. Disassembling KDDI Kyocera A5521K Faceplate: adım 6, 1 resimden 1.
    • Use the Y0 screwdriver to remove the screws.
  7. Disassembling KDDI Kyocera A5521K Faceplate: adım 7, 2 resimden 1. Disassembling KDDI Kyocera A5521K Faceplate: adım 7, 2 resimden 2.
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. Disassembling KDDI Kyocera A5521K Faceplate: adım 8, 3 resimden 1. Disassembling KDDI Kyocera A5521K Faceplate: adım 8, 3 resimden 2. Disassembling KDDI Kyocera A5521K Faceplate: adım 8, 3 resimden 3.
    • Separate the faceplate from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominic Grisafe
157 İtibar
10 adet Kılavuz yazıldı
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G25
4 Üyeler
20 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,663
