Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the four screws with the Y0 screwdriver. Remove the four screws with the Y0 screwdriver.
    • Remove the four screws with the Y0 screwdriver.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws. Remove the two screws with a Y0 screwdriver.
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Rotate the phone 180 degrees. Carefully separate the back plate from the remainder of the phone. The back plate should now be detached from the rest of the phone.
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift up the bottom of the logic board. Carefully remove the logic board from the lower half of the phone. The logic board is connected to the remainder of the phone by two cables at the upper right corner indicated by the red circle.  Do not damage the cables.
    • Lift up the bottom of the logic board.
    • Carefully remove the logic board from the lower half of the phone.
    • The logic board is connected to the remainder of the phone by two cables at the upper right corner indicated by the red circle. Do not damage the cables.
  7. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Gently lift the keyboard up with a spudger. The keyboard is now separate from the remainder of the phone and can be easily removed.
    • Gently lift the keyboard up with a spudger.
    • The keyboard is now separate from the remainder of the phone and can be easily removed.
Bitiş Çizgisi
Dominic Grisafe
157 İtibar
10 adet Kılavuz yazıldı
Takım
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G25
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,248
