Ana içeriğe geç
Disassembling KDDI Kyocera A5521K Logic Board
Neye ihtiyacın var
  1. Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: adım 1, 3 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: adım 1, 3 resimden 2. Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: adım 1, 3 resimden 3.
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Logic Board: adım 2, 3 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board: adım 2, 3 resimden 2. Disassembling KDDI Kyocera A5521K Logic Board: adım 2, 3 resimden 3.
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: adım 3, 2 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: adım 3, 2 resimden 2.
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K Logic Board: adım 4, 2 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board: adım 4, 2 resimden 2.
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Logic Board: adım 5, 3 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board: adım 5, 3 resimden 2. Disassembling KDDI Kyocera A5521K Logic Board: adım 5, 3 resimden 3.
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  6. Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: adım 6, 3 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: adım 6, 3 resimden 2. Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: adım 6, 3 resimden 3.
    • Rotate the phone approximately 45 degrees to the right.
    • Gently pry up the SD card slot with a spudger.
  7. Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: adım 7, 3 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: adım 7, 3 resimden 2. Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: adım 7, 3 resimden 3.
    • Lift up on the first connection shown using a pair of pliers.
    • Disconnect the first connection between the logic board and the wire using the pair of pliers.
  8. Disassembling KDDI Kyocera A5521K Logic Board: adım 8, 3 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board: adım 8, 3 resimden 2. Disassembling KDDI Kyocera A5521K Logic Board: adım 8, 3 resimden 3.
    • Repeat the above steps for the second connection.
    • Use the pliers to pry up the connection.
    • Use the pliers to disconnect the connection between the logic board and the wire.
  9. Disassembling KDDI Kyocera A5521K Logic Board: adım 9, 1 resimden 1.
    • Lift up on the bottom of the logic board with a spudger.
    • Gently remove the rest of the logic board from the phone.
  10. Disassembling KDDI Kyocera A5521K Logic Board: adım 10, 2 resimden 1. Disassembling KDDI Kyocera A5521K Logic Board: adım 10, 2 resimden 2.
    • The logic board should now be completely disconnected from the phone.
Sonuç
Dominic Grisafe
157 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G25
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,775
