Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover
Neye ihtiyacın var
  1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: adım 1, 2 resimden 1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: adım 1, 2 resimden 2.
    • Using a spudger, gently pry off the aluminum drip ring.
  2. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 2, 1 resimden 1.
    • Using a 1 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 3, 2 resimden 1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 3, 2 resimden 2.
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 4, 1 resimden 1.
    • Using a flathead screwdriver, remove the five, 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two, 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 5, 1 resimden 1.
    • Turn your device around. Using the same flathead screw driver, remove the two, 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 6, 2 resimden 1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 6, 2 resimden 2.
    • Using a phillips 2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 7, 2 resimden 1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 7, 2 resimden 2.
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: adım 8, 1 resimden 1.
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside down to prevent grease from leaking out.
Sonuç
32 farklı kişi bu kılavuzu tamamladı.
Chris Gonzales
1.519 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G28
4 Üyeler
22 adet Kılavuz yazıldı
24 Yorum
Well fine job! Just finished and t works!!!
James Anderson - Yanıt
Instruccion is exelent but I veleave the problem is electric. can you give aidea. dhe machine does’nt work at all
Aristides Aleman - Yanıt
Thank you! I'm repainting my white mixer a deep cherry red gloss to match my kitchen. These mixers can last 20+ years, if you take care of them. But, who wants the same color kitchen for that long? Bonus: saved $50+ by painting it the color I wanted, rather than pay the extra for a mixer from the colored choices.
Heather Schrader - Yanıt
Do the motor housing sometimes become to hard to remove? I followed all the steps yet it still acts as if something inside the housing is keeping it from coming off.
Royce M - Yanıt
Nothing else, only the planetary assembly, and the 9 big housing screws. Once those are off, it can take a lot of jiggling and persistence, mostly because there’s a vacuum between the vertical shaft and the bushing inside. Remember to loosen the cord in case to prevent yanking it accidentally when the cover comes off.
Ariel Cornejo -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 30
Son 7 gün: 274
Son 30 gün: 1,194
Her zaman: 96,632
