Ana içeriğe geç
Disassembling Kitchenware Rival Coffee Maker
Neye ihtiyacın var
  1. Disassembling Kitchenware Rival Coffee Maker, Rival Single Cup Coffee Maker: adım 1, 1 resimden 1.
    • Make sure the coffee maker is unplugged before proceeding.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Kitchenware Rival Coffee Maker, Unscrewing  Metal Base: adım 2, 1 resimden 1.
    • Locate and unscrew the 3 8mm Three-pronged Y screws at the bottom of the coffee maker base.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: adım 3, 3 resimden 1. Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: adım 3, 3 resimden 2. Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: adım 3, 3 resimden 3.
    • Locate the white securing tab on the front rounded metal base. Push up on the plastic with the tip of your thumbs until the metal base is clear from the tab.
    • Remove the metal base from the coffee maker.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Kitchenware Rival Coffee Maker, Removing Power Cable Screws: adım 4, 2 resimden 1. Disassembling Kitchenware Rival Coffee Maker, Removing Power Cable Screws: adım 4, 2 resimden 2.
    • Remove the two 13mm Phillips screws to release the power cord.
    • Remove the white cap from the screw holder.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Kitchenware Rival Coffee Maker, Removing Bottom Chassis Screws: adım 5, 2 resimden 1. Disassembling Kitchenware Rival Coffee Maker, Removing Bottom Chassis Screws: adım 5, 2 resimden 2.
    • Remove the two 8mm Phillips screws from the metal chassis.
    • Remove the two black screw caps.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Power Button: adım 6, 1 resimden 1.
    • Remove the 7mm Phillips screw from the power button.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Kitchenware Rival Coffee Maker, Removing Power Button: adım 7, 2 resimden 1. Disassembling Kitchenware Rival Coffee Maker, Removing Power Button: adım 7, 2 resimden 2.
    • Use a spudger or a flat head screwdriver to pull the white tab away from the power button body.
    • Pull the power button to the left of the tab until it is free from the tab. Then push the power button through the coffee makers body and let it sit inside the coffee makers body.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Kitchenware Rival Coffee Maker, Removing Power button from Cable: adım 8, 1 resimden 1.
    • Remove the 7mm Phillips screw from the motherboard of the power button.
    • Pull the white plastic body away from the logic board.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: adım 9, 3 resimden 1. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: adım 9, 3 resimden 2. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: adım 9, 3 resimden 3.
    • Remove the 4 13mm Phillips screws from the four corners of the case to release the bottom half of the coffee maker.
    • These screws are very deep and you may need a longer thinner screwdriver for it.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Kitchenware Rival Coffee Maker: adım 10, 3 resimden 1. Disassembling Kitchenware Rival Coffee Maker: adım 10, 3 resimden 2. Disassembling Kitchenware Rival Coffee Maker: adım 10, 3 resimden 3.
    • Tilt the bottom half of the coffee maker forward.
    • Pull up until it is free from the top half while feeding the power cable down through the plastic body.
    • Be gentle while removing the bottom half as the cables to the power button are very fragile.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Michael
226 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 2,149
