Ana içeriğe geç
Disassembling Kodak Advantix F350 Back Cover
Neye ihtiyacın var
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: adım 1, 1 resimden 1.
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: adım 2, 2 resimden 1. Disassembling Kodak Advantix F350 Back Cover: adım 2, 2 resimden 2.
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: adım 3, 3 resimden 1. Disassembling Kodak Advantix F350 Back Cover: adım 3, 3 resimden 2. Disassembling Kodak Advantix F350 Back Cover: adım 3, 3 resimden 3.
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: adım 4, 2 resimden 1. Disassembling Kodak Advantix F350 Back Cover: adım 4, 2 resimden 2.
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: adım 5, 2 resimden 1. Disassembling Kodak Advantix F350 Back Cover: adım 5, 2 resimden 2.
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: adım 6, 3 resimden 1. Disassembling Kodak Advantix F350 Back Cover: adım 6, 3 resimden 2. Disassembling Kodak Advantix F350 Back Cover: adım 6, 3 resimden 3.
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Cottrell
103 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team 1-2, Zhou Fall 2011 UW Stout, Team 1-2, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,215
