Ana içeriğe geç
  1. Turn off the camera.
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Locate the 3 screws that hold the back cover to the camera. One screw is located on the film opener side of the camera.
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Apple Watch Kitleri
    Screen and battery repairs just got easier.
    Hemen Alışveriş Yapın
    Apple Watch Kitleri
  4. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  5. Open the film door to remove the back cover. Slide the film door lever to the left until the film door opens.
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  6. Use a plastic opening tool to pry the case open until a small gap is present. Repeat this process at the top and bottom of the film door to loosen it.
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  7. Grab the top and bottom of the case firmly as shown. Gently remove the back of the camera case with a slight twisting motion. Gently remove the back of the camera case with a slight twisting motion.
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Sonuç
David Cottrell
58 İtibar
5 adet Kılavuz yazıldı
Takım
UW Stout, Team 1-2, Zhou Fall 2011 UW Stout, Team 1-2, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 5
Her zaman: 463
