Ana içeriğe geç
Disassembling Kodak Advantix F350 Front Cover
Neye ihtiyacın var
    1. Disassembling Kodak Advantix F350 Front Cover, Back Cover: adım 1, 1 resimden 1.
      • Turn off the camera.
      • Locate the power switch on the front of the camera below the camera lens.
      • Slide the switch to the off position.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Kodak Advantix F350 Front Cover: adım 2, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 2, 2 resimden 2.
      • Locate the 3 screws that hold the back cover to the camera.
      • One screw is located on the film opener side of the camera.
      • The other screws are located on the opposite side of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Kodak Advantix F350 Front Cover: adım 3, 3 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 3, 3 resimden 2. Disassembling Kodak Advantix F350 Front Cover: adım 3, 3 resimden 3.
      • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling Kodak Advantix F350 Front Cover: adım 4, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 4, 2 resimden 2.
      • Open the film door to remove the back cover.
      • Slide the film door lever to the left until the film door opens.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling Kodak Advantix F350 Front Cover: adım 5, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 5, 2 resimden 2.
      • Use a plastic opening tool to pry the case open until a small gap is present.
      • Repeat this process at the top and bottom of the film door to loosen it.
      FixBot'a Sor
      Yorum Ekle
    6. Disassembling Kodak Advantix F350 Front Cover: adım 6, 3 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 6, 3 resimden 2. Disassembling Kodak Advantix F350 Front Cover: adım 6, 3 resimden 3.
      • Grab the top and bottom of the case firmly as shown.
      • Gently remove the back of the camera case with a slight twisting motion.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Kodak Advantix F350 Front Cover, Front Cover: adım 7, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover, Front Cover: adım 7, 2 resimden 2.
      • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
      • The first 2 are located on the bottom of the camera.
      • The last screw is located behind the flash module.
      • Turn the camera on, and raise the flash module to locate the flash module screw.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Kodak Advantix F350 Front Cover: adım 8, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 8, 2 resimden 2.
      • Remove the 2 screws at the base of the camera housing.
      • Use the Phillips #00 Precision Screwdriver and remove the screws.
      • Repeat this process for the screw behind the flash module.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Kodak Advantix F350 Front Cover: adım 9, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 9, 2 resimden 2.
      • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling Kodak Advantix F350 Front Cover: adım 10, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 10, 2 resimden 2.
      • Remove the flash cover.
      • Remove the flash module by twisting it up and outward of the camera housing.
      • The cover can now be be removed.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling Kodak Advantix F350 Front Cover: adım 11, 2 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 11, 2 resimden 2.
      • Remove the film door lever.
      • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
      • Using a plastic opening tool, gently pry the switch upwards to remove it.
      FixBot'a Sor
      Yorum Ekle
    6. Disassembling Kodak Advantix F350 Front Cover: adım 12, 1 resimden 1.
      • Open the battery door by pushing the lever towards the arrow indicated.
      FixBot'a Sor
      Yorum Ekle
    7. Disassembling Kodak Advantix F350 Front Cover: adım 13, 3 resimden 1. Disassembling Kodak Advantix F350 Front Cover: adım 13, 3 resimden 2. Disassembling Kodak Advantix F350 Front Cover: adım 13, 3 resimden 3.
      • Remove the front cover.
      • Insert your thumb in the film hole and gently pry the bottom loose.
      • Once the front is loose, gently pull it out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
David Cottrell
103 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team 1-2, Zhou Fall 2011 UW Stout, Team 1-2, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 1,347
