Ana içeriğe geç
Disassembling Kodak Easyshare C813 Back Cover
Neye ihtiyacın var
  1. Disassembling Kodak Easyshare C813 Back Cover, Battery: adım 1, 1 resimden 1.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Back Cover: adım 2, 3 resimden 1. Disassembling Kodak Easyshare C813 Back Cover: adım 2, 3 resimden 2. Disassembling Kodak Easyshare C813 Back Cover: adım 2, 3 resimden 3.
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Back Cover, Back Cover: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
  4. Disassembling Kodak Easyshare C813 Back Cover: adım 4, 1 resimden 1.
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Back Cover: adım 5, 3 resimden 1. Disassembling Kodak Easyshare C813 Back Cover: adım 5, 3 resimden 2. Disassembling Kodak Easyshare C813 Back Cover: adım 5, 3 resimden 3.
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Disassembling Kodak Easyshare C813 Back Cover: adım 6, 3 resimden 1. Disassembling Kodak Easyshare C813 Back Cover: adım 6, 3 resimden 2. Disassembling Kodak Easyshare C813 Back Cover: adım 6, 3 resimden 3.
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Disassembling Kodak Easyshare C813 Back Cover: adım 7, 3 resimden 1. Disassembling Kodak Easyshare C813 Back Cover: adım 7, 3 resimden 2. Disassembling Kodak Easyshare C813 Back Cover: adım 7, 3 resimden 3.
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Disassembling Kodak Easyshare C813 Back Cover: adım 8, 3 resimden 1. Disassembling Kodak Easyshare C813 Back Cover: adım 8, 3 resimden 2. Disassembling Kodak Easyshare C813 Back Cover: adım 8, 3 resimden 3.
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Susan Marano
336 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G22
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 2,452
