Ana içeriğe geç
Disassembling Konica Compact 8 Front Cover
Neye ihtiyacın var
    1. Disassembling Konica Compact 8 Front Cover, Left side screw: adım 1, 1 resimden 1.
      • Remove the screw on the left side if the camera is facing your way.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Konica Compact 8 Front Cover, Right side screw: adım 2, 1 resimden 1.
      • Remove the screw on the right side if the camera is facing you.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Konica Compact 8 Front Cover: adım 3, 1 resimden 1.
      • Now remove the final screw at the top of the camera. You can now remove the top cover carefully.
      • You can pry the front cover up and down to loosen it. Be careful not to pry horizontally and only vertically. This is because of the open aperture blades that are on the sides.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling Konica Compact 8 Front Cover, Finish: adım 4, 1 resimden 1.
      • The machinery is now open and can be dissasembled further or the front cover might be cleaned freely without worry that cleaning liquid would seep into the camera.
      • Make sure to remember what the "roll and lock" switch was on before dissassembly or to not touch it at all.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling Konica Compact 8 Front Cover, Optional: Pushing lever back in place when reassembling: adım 5, 1 resimden 1.
      • You might need to push the brass lever that holds the wires in place (right under the small board on the leftside) up to fit the front cover back on.
      • If its stuck in place in the wrong position, loosen the screw attached to it a little bit to pry it back in it's original position.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. You might need to push the brass lever that holds the wires in place (right under the small board on the leftside) up to fit the front cover back on. Mine had shifted downwards after taking the cover off and the topcover did not fit back because of it. If its stuck in place in the wrong position, loosen the screw attached to it a little bit to pry it back in it's original position.
JonasB7
485 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 126
