Ana içeriğe geç
Disassembling LG 440G Rear casing
Neye ihtiyacın var
  1. Disassembling LG 440G Rear casing, Turn off phone.: adım 1, 1 resimden 1.
    • Turn the device off.
    • To do so, press and hold the red button.
  2. Disassembling LG 440G Rear casing, Flip phone.: adım 2, 1 resimden 1.
    • Flip the phone over.
  3. Disassembling LG 440G Rear casing, Rear cover removal.: adım 3, 1 resimden 1.
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. Disassembling LG 440G Rear casing, Removal of battery.: adım 4, 1 resimden 1.
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. Disassembling LG 440G Rear casing, Unscrew six screws along edges of casing: adım 5, 1 resimden 1.
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. Disassembling LG 440G Rear casing, Lift casing cover: adım 6, 2 resimden 1. Disassembling LG 440G Rear casing, Lift casing cover: adım 6, 2 resimden 2.
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
Sonuç
Emily Class
107 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Buehl Winter 2015 Ohio State, Team 1-1, Buehl Winter 2015 üyesi
OSU-BUEHL-W15S1G1
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
this would be most probably, the same guide to tear down the LG B470
douglas flores - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,648
