Ana içeriğe geç
Disassembling LG VX8300 Body
Neye ihtiyacın var
    1. Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: adım 1, 3 resimden 1. Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: adım 1, 3 resimden 2. Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: adım 1, 3 resimden 3.
      • Power off the device by holding down the red button labeled PWR.
      • Be sure that the phone is powered off before touching the battery to avoid danger.
      • Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling LG VX8300 Body: adım 2, 2 resimden 1. Disassembling LG VX8300 Body: adım 2, 2 resimden 2.
      • Place your finger into the semicircle gap on top of the battery.
      • Apply force downward and out, so the battery pops out of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling LG VX8300 Body: adım 3, 3 resimden 1. Disassembling LG VX8300 Body: adım 3, 3 resimden 2. Disassembling LG VX8300 Body: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Locate the two rubber pads covering the screws at the top of the phone near the hinge.
      • Use tweezers to lift and remove the rubber pads.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling LG VX8300 Body: adım 4, 2 resimden 1. Disassembling LG VX8300 Body: adım 4, 2 resimden 2.
      • Use a Phillips #00 screwdriver to remove all four 3mm screws from the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling LG VX8300 Body: adım 5, 2 resimden 1. Disassembling LG VX8300 Body: adım 5, 2 resimden 2.
      • Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
      • Remove the casing after it has been detached. The logic board is now fully accessible.
      • Once the body case is removed, the volume and camera buttons move freely. Ensure all loose pieces remain accounted for.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
nvalm
448 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-7, Duarte Spring 2015 UMass Dartmouth, Team 3-7, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G7
3 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 980
