Ana içeriğe geç
Disassembling LG VX8550 Front Case
Neye ihtiyacın var
    1. Disassembling LG VX8550 Front Case, Battery: adım 1, 1 resimden 1.
      • Slide the battery release up.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling LG VX8550 Front Case: adım 2, 1 resimden 1.
      • Remove the battery by lifting away from the case.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling LG VX8550 Front Case, Case: adım 3, 1 resimden 1.
      • Remove the 2 screw covers next to the rear speaker with a Push Pin.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling LG VX8550 Front Case: adım 4, 1 resimden 1.
      • Remove the 4 cover screws with a Philips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling LG VX8550 Front Case: adım 5, 1 resimden 1.
      • Use the iPod opening tool to pry off the back casing.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling LG VX8550 Front Case: adım 6, 1 resimden 1.
      • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling LG VX8550 Front Case: adım 7, 1 resimden 1.
      • Separate the casing halves.
      • Be sure to keep track of the side buttons as they fall out.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling LG VX8550 Front Case, Motherboard: adım 8, 1 resimden 1.
      • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling LG VX8550 Front Case: adım 9, 1 resimden 1.
      • Carefully lift up on the motherboard to see the ribbon cables underneath.
      • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling LG VX8550 Front Case: adım 10, 1 resimden 1.
      • Remove the motherboard from the front casing by lifting straight up.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling LG VX8550 Front Case, Keypad Housing: adım 11, 1 resimden 1.
      • Lay the phone with the screen facedown.
      • The 6 slider screws are visible.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling LG VX8550 Front Case: adım 12, 1 resimden 1.
      • Peel back but don't remove the blue tape to access the 2 center screws.
      • Remove the 6 slider screws with the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling LG VX8550 Front Case: adım 13, 1 resimden 1.
      • Lift the keypad housing away from the slider.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling LG VX8550 Front Case, Front Case: adım 14, 1 resimden 1.
      • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling LG VX8550 Front Case: adım 15, 1 resimden 1.
      • Remove the 6 screws with a Phillips #00 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling LG VX8550 Front Case: adım 16, 1 resimden 1.
      • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling LG VX8550 Front Case: adım 17, 1 resimden 1.
      • Carefully lift the slider mechanism to see the ribbon cables underneath.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling LG VX8550 Front Case: adım 18, 1 resimden 1.
      • Slide ribbon cable through the slider mechanism.
      FixBot'a Sor
      Yorum Ekle
    6. Disassembling LG VX8550 Front Case: adım 19, 1 resimden 1.
      • Separate the two halves.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nathan Jones
89 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G55
5 Üyeler
110 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 2,427
